Hi Eric, I have removed those cells from my 77 diesel. The inner cell body is, indeed, threaded on the inside. I found out mine was 11/16-20, an odd size. I wound up making a puller with that thread on it in order to get the damn things out. My I&T manual, No. O-10 covers both the 77 and the 770, among others. There is no indicated difference between the 77 and the 770 so I would guess yours would be the same as mine. It is odd though that my manual indicates this thread to be 15/16-20, which is incorrect, and yours indicates 3/4-16 which you say is too big. I'll put my bets on the 11/16-20, the same as mine. I don't know where you can buy a bolt with that thread on it...you will probably have to make one or get one made. The threads are fine and are difficult to see in that inner cell body, especially is there is a lot of carbon built up. Once you get the right thread though, they come out rather nicely, although hard, as I recall. This is a much better way than beating on them from the inside with a drift. It really is better if you can get them out rather than trying to clean them in place...worth making the special puller. Good luck, Rod
