1800 Injector pump and air
Larry W.
05-29-2002 05:26:40
I'm new here guys so have pity on me. I usually am over at the red or other green board, but just bought this 1800 yesterday cause I needed some power. Anyway, seems like the injectors aren't getting fuel in the engine. there was some air in the lines, but I have bled at the filters and pump, but it won't start. I am new to diesels, and need some advice to get it running. thanks.
Larry from Maryland
05-29-2002 09:20:33
 Re: 1800 Injector pump and air in reply to Larry W., 05-29-2002 05:26:40
The 1800 allso needs to have the electric wire hooked up and power on when the switch is on.
Jethro
05-29-2002 07:43:17
You also need to bleed at the injector also to get all the air out
Larry W.
05-29-2002 15:36:07
 Re: Re: 1800 Injector pump and air in reply to Jethro, 05-29-2002 07:43:17
Update. thanks for the answers. I disconnected the fuel lines at the pump. It was not pumping fuel to the injectors. The local injector pump repair man said "Check the metering valve, I bet it's stuck." Sure enough that was it. Now the pump is off and in the guy's shop gettin a bunch of money spent on it. I will be completely broke, but the 1800 will be running in about a week.
