Tractor pull
kevin m
05-28-2002 18:57:01
SUNDAY IWENT TO A PULL AND NOTICED THAT THERE WAS NO 77'S PULLING AND ALOT OF 88'S. ARE THEY BETTER? CIMILAR IN WEIGHT? I KNOW THE 88'S HAVE MORE CUBES. THE REASON I AM ASKING IS IHAVE A 77 TOR APART AND AM WOUNDERING BEFORE I PUT ANY MONEY IN IT IF I SHOULD LOOK FOR AN 88??
SHANX FOR ANY HELP ..
Keddano
05-31-2002 21:40:10
 Re: tractor pull in reply to kevin m, 05-28-2002 18:57:01
Kevin,I'm in the progress of right now building a 77,With the e-mail advice of someone on this board.At this time I'm doing headwork(cut down chevy valves,shaving and porting),Looking for a better manifold,and carb.The pistons will come next winter.We'll see how well she does in a few weeks.The only thing I regret is I pulled the PTO out. Found out now a friend of mine has a PTO dyno.I'd like'd to found out what each change gave me.But then again he runs Deeres. I'll post how thing turn out.May get it back together for next weekend. Dan
kspuller
05-29-2002 18:08:14
You guessed one of the answers in the fact that you can get an 88 in the same weight classes. I pull my 77 against my brothers 88 but in stock classes with tire size limits his power can also be his undoing.
WFE
05-30-2002 08:26:27
 Re: Re: tractor pull in reply to kspuller, 05-29-2002 18:08:14
I've been curious since I first saw your nickname, kspuller, about how popular tractor pulling is in Kansas. I was not under the impression that they had yet spread into Kansas to any great degree. I would assume they are mostly in the eastern part of the state, is that correct? Perhaps they are predominantly located along the Missouri border, or do they go as far west into Kansas as Wichita, Topeka, Salina, Hutchinson, etc? Or are they only in the northeast part, not being popular as far south as Wichita? Just curious as I get into Kansas on occasion. There's a good old Oliver dealer and following around Durham, KS with the dealer G and R Equipment in Durham. You know them?
Best Regards,
WFE
kspuller
06-03-2002 18:01:30
 Re: Re: Re: tractor pull in reply to WFE, 05-30-2002 08:26:27
I belong to the Heartland Antique Tractor Pullers Assc., Inc. The club covers the NE part of Ks. The club has its own sled (Heartbreaker) and portable scales. We have around 50 members and 14 pulls are scheduled with 2 completed. Towns in Ks. where we pull are Salina, Washington, Summerfield, BlueRapids, Junction City, Minneapolis, Belleville, Axtell, Beattie, Oketo, and Clyde. The club normally pulls Divs. 2 and 3.
WFE
05-29-2002 09:42:07
The biggest advantage the 88 has over the 77 is stroke. The block has more room for crank swing and thus can accommodate a longer stroke and stroker crankshaft, resulting in even more cubic inch displacement possibilities. Stroker crankshafts aren't cheap, so if you know that you are not going to ever try a stroker crank, a 77 can fit the bill nicely. The 77s can also be stroked, but not to the extent that the 88s can. In addition, the 88 has a longer stroke to begin with, so guys who don't use stroker cranks have an advantage running a stock 88 stroke against a stock 77 stroke. Both can be bored of course, but the 88 block also allows a larger bore if you wish. So the 88 engine does afford more opprotunities for big horsepower than the 77 does, at minimal marginal weight. Having said that, 77s can and do still do quite well, even against big Ms and JD Gs that have numerous performance parts available. I pull 77s and would like to have a Super 88 someday, but don't know if I'll ever stroke one, so the 77 does just fine with bigger bore, more compression, higher rpms, bigger valves, and bigger carb. Depends how competitive you need to be.
kevin m.
05-29-2002 18:45:41
 Re: Re: tractor pull in reply to WFE, 05-29-2002 09:42:07
I just got off the phone with an old oliver wizard who suped olivers up three decades ago. he said to do some cam work, is there any oversized cam that would slide in or do i need to have one built up and reground (sounds expensive). but he said basicaly what you said.
thanks again
WFE
05-30-2002 08:14:53
 Re: Re: Re: tractor pull in reply to kevin m., 05-29-2002 18:45:41
Kevin,
I don't know if any stock Oliver cam that would provide more lift and/or duration would fit into a 77 block. We send the camshaft to a machine shop to have it built up and reground and they seem to know what they're doing because you can indeed tell a difference in low end performance and overall power from the stock cam. Seems to me it runs in the neighborhood of $300, which is far less than a stroker crank will cost you. Big 3 3/4" pistons and more compression from either domed pistons or shaving the head do you the most good. Then, one can look at the other things like big valves, carb, and modified cam. Good luck and best regards,
WFE
