Coop E3
Greg Lemke
05-28-2002 07:55:02
i am looking for info on a coop e3. a buddy here at work bought one and is looking for production numbers, year built, and original paint colors. it has these numbers
T-98D-3C-1
13214 R 29 0
Jeff
07-23-2002 13:46:46
 Re: Coop E3 in reply to Greg Lemke, 05-28-2002 07:55:02
Can someone tell me the correct tire/wheel size for a Coop E3? Thanks.
Kent
05-28-2002 18:36:10
Greg, the serial # is on the cast frame of the tractor. It is on the left side, and stamped into the casting, by the engine. The numbers you have are from the Buda engine I believe. The serial number will be 30-##### probably. It is facing up and probably covered in grease. It is the same as the cockshutt 30. If you get the number it is easy to determine the year. Let us know
Greg Lemke
05-29-2002 05:18:54
 Re: Re: Coop E3 in reply to Kent, 05-28-2002 18:36:10
The serial number is 30 28151. Dose this help
Kent
05-29-2002 09:54:38
 Re: Re: Re: Coop E3 in reply to Greg Lemke, 05-29-2002 05:18:54
Greg, My info tells this is a 1950 model. Where did the numbers come from that you first posted? If they were from the motor something is missing, I think.
Al
05-29-2002 08:55:53
it'a a 1951
