Changing hydro-power fluid in 1650
Bacman
05-27-2002 19:49:53
Is there anything I can use for the 2 speed other than Type A fluid? It is hard to find around here. Thanks.
WFE
05-27-2002 20:25:11
 Re: Changing hydro-power fluid in 1650 in reply to Bacman, 05-27-2002 19:49:53
You bet. Any automatic transmission fluid is suitable for the Hydra-Powers and Over/Unders. Type F, which is commonly used in Fords, is the closest widely available fluid to the old Type A which Oliver specified. However, Dexron/Mercon fluid is also suitable to use in the Hydra-Power, and I've been told is actually a better fluid than Type F so it is what I put in. I know some people also run hydraulic oil in these units without any problems, and it certainly works well, but transmission fluid is more highly refined and is what Oliver called for. I figure that if they thought hydraulic oil was better suited to use in the Hydra-Powers, they would have specified it in the first place. All in all, they are very forgiving and you can use either one you prefer.
Johnnie
06-05-2002 19:59:40
 Re: Re: Changing hydro-power fluid in 1650 in reply to WFE, 05-27-2002 20:25:11
I have used Cat 30wt. hyd fuild in my 1650 hydro power for the last 8 yrs have had no problems.
