Oil leak
Tim
05-27-2002 10:23:40
I just overhauled the engine on an 88 Gas and when I went to load it on the trailer it started to leak oil from the clutch housing. What could be the cause? I installed a new rear seal. Any help appreciated.
RAB
05-27-2002 23:22:21
 Re: Oil leak in reply to Tim, 05-27-2002 10:23:40
Rear Oil Seal. Don't know what type is fitted but maybe not fitted quite straight, central, maybe damaged or even faulty manufacture. If its a normal modern type, the sealing lip could possibly have 'rolled over' on installation, or the lip is sitting just on a wear groove from the previous one. At this stage you might as well run it a bit to see if it seals, before splitting it again. Keep the engine oil level down near the fill-mark on dipstick to minimise any more oil loss and keep rpm down. RAB
