Oliver Super 55 Clutch
bigjohn
05-27-2002 05:03:23
I have just split my oliver 55 and it appears that the throw-out bearing froze. In the process it wore the fingers off the clutch release plate so I am into replacement of the clutch assembly and the throughout bearing. Can I obtain these parts from my local auto parts dealier, if so what are the part numbers that I would use. If no, can I obtain the same from one of the old time oliver parts dealiers. I also need the actuator rod for the clutch and the linkage sine the last repair was a cob-job that doesn,t work very well.
ken
05-27-2002 07:37:10
 Re: Oliver Super 55 Clutch in reply to bigjohn, 05-27-2002 05:03:23
Hi, I think everything you need is available from Maibach tractor 1-800-808-9934 ask for Tom. hope this helps Ken
