550
PTO Inspection Port Cleaning
Clay
05-26-2002 19:22:53
Just adjusted the PTO clutch for the first time. The adjustment was easy enough (4 clicks), but found a different problem. One of the fittings for the bearing grease line let go some time ago. Grease is covering everything. Maybe why it needed adjusting?
So, two questions: Shouldn't the area be dry and fairly clean since the clutch is there? Is it a good idea to spray the whole area out with parts cleaning solvent or diesel, then let it dry completely before using the PTO? How about brake cleaner? It's working now so maybe I should leave well enough alone. Just don't want to ruin the clutch prematurely (with grease, solvent, etc).
If anyone has run into this before, please let me know. Thanks, Clay
