Pull PTO Shaft to lighten tractor
Little Ollie
05-22-2002 14:50:15
Trying to lighten up the old 77 for pulling,someone told me you can remove it and just make a plate to cover were it was.Someone else said you have to add a bearing to support something when you remove it.what's the real story? Thanks
evielboweviel
05-24-2002 06:56:17
 Re: Pull PTO Shaft to lighten tractor in reply to Little Ollie, 05-22-2002 14:50:15
If you removed the pto shaft and still wanted to have hydraulics then you would install a short shaft which needs a bearing for support. However you are trying to lighten the tractor up and will not have a hydraulic unit on it.
kspuller
05-22-2002 15:58:28
All I have ever done is unbolt and pull the pto and make a cover for the hole.
