One thing you have to remember is that them IH 966 and JD 4430 engines have over 30% more cubes than the 310 Waukasha engine. That means they can make more HP and Torque easily rather than the Oliver engine. And the 310 is not known to be a really strong engine till it is reworked right, but even then, it is still 310 cubic inches where a 966 IH is over 100 cubes bigger. I have seen a few Oliver 2255's with a 3208 Cat engine,... They are over 630 cubes, and are rather easy to build up. And relatively a lot cheaper than putting a ton of $$$$ into the 310 for rods, crank, etc and still be under HP compared to the competition. There is only so much HP you can squeeze out of a cube,.... so I would not bother with the 310,... They are good to 120-130 hp if reworked correctly,... But going past that is playing with the devil,.. (Will definately go south on you),.. But don't know how long it will hold up to that punishment.
