Oliver OC-4 hydraulic valve
Andrew
05-18-2002 19:27:39
I have an Oliver OC 4 - 3G -31- Series B crawler tractor. The metal ring at the underside of the hydraulic valve body broke off. I have the ring and the set screws which hold it on, as well as the seal for the rod (through the valve body) which is connected to the linkage to raise and lower the blade. I reassembled the system but now have a major leak around the top of the metal ring. Is there a seal between the metal ring and the valve body ? Can someone tell me more about the configuration of the valve in this area ?
THANKS, ANDREW E-mail [email protected]
