INTERCHANGE APPLICATION HELP
Gary
05-18-2002 10:30:46
I would like clarification help for CAB interchange. I currently have a 1600 series tractor and would like to put a cab on it. I am told 1500/1550/1555 or 1600/1650/1655 are the only tractors that will interchange. Comments or suggestions would be appreciated.
Wrenchbender
05-18-2002 15:38:05
 Re: INTERCHANGE APPLICATION HELP in reply to Gary, 05-18-2002 10:30:46
Yes in general I would say that you need a cab from one of those models. They are all the same size rear end and axle housing. Most cabs mount to the holes on the axle housing and holes in the frame sides. The larger tractors ie 17-18-19xx have larger axle housings and may be a different lenght from axle to frame mounting holes. I do not have a 15-16xx tractor that I can measure to tell you if there is a difference. Sorry I can not give you an exact answer. Are you looking for an Oliver cab or just a cab of any kind? WB.
gary
05-18-2002 19:54:52
 Re: Re: INTERCHANGE APPLICATION HELP in reply to Wrenchbender, 05-18-2002 15:38:05
At this time any good condition cab would be a candidate, Thanks
