Oliver 70 Question
Bobduck
05-15-2002 20:37:40
Got my 70 out of mothballs and fired up for the summer.
Have a question.
There's a hole on the right side, low below the insturment panel that I don't know the function of.
It looks like there was an electrical wire running to it at one time.
Here's a link to a large picture of the hole.
Any help you can give as to what this is for would be appreciated.
Thanks
Bobduck
COWBOY
05-17-2002 04:45:30
 Re: Oliver 70 Question in reply to Bobduck , 05-15-2002 20:37:40
In the pic you provided there are 2 holes I can see,...
The one that is bigger is what I described before (For the foot throttle)
But the other hole in the very lower corner is about 1/2 inch in diameter,... It is on all 3 of my Oliver 70's (Industrial and Row Crop) and there are no uses for it that I know of.
Maybe they were alignment holes for fabrication when the panel was made. There is one on the left side also,.,..
Maybe they were put there for a reason, but that is beyond me!
Terry
05-16-2002 16:07:01
This hole is not like the one used on the industrial to run the foot throttle through, and the lever to switch from gas to kerosene on the kd model was on the other side, and a lot smaller hole. This looks like someone has modified it to be some sort of a light socket connector, or a cigarette lighter. Definitely after market.
COWBOY
05-16-2002 09:05:29
The hole you are speaking about is about 1 inch in diameter, with two 1/4 inch holes just above it.
It was for the Foot Throttle rod to go through. Most Industrial, Standard, and some Row Crops had foor throttles, or were added later.
Foot throttles worked in conjunction with the existing hand throttle on the steering column. They were great for using a loader, or when you needed more power quickly, then letting it go back to 1/2 throttle.
I can post a pic on here of my Industrial 70 if you need one to see what a foot throttle and linkage look like if needed.
Geoffrey Heck
05-16-2002 07:23:02
It could have been a KD engine at one time and the lever to switch from gas to kerosene. I don't know for sure but it is just my opinion.
bobduck
05-16-2002 12:29:29
 Re: Re: Oliver 70 Question in reply to Geoffrey Heck, 05-16-2002 07:23:02
This one doesn't have two 1/4" holes above the bigger hole.
It also looks like there was an electrical lead to this socket.
Yes, I would like to see pictures.
Thanks.
B'duck
