Oliver 70 Battery
Jerry in CA
05-11-2002 22:40:02
I have a '47 Oliver 70 Standard that is ready to start. Is this a 6 volt system? Positive ground? It has a generator that is stamped 12 volt but is obviously not the original. What do I try? Thanks in advance for your help.
Jerry in CA
05-12-2002 22:13:23
 Re: Oliver 70 Battery in reply to Jerry in CA, 05-11-2002 22:40:02
Thanks for all the advice. Maybe this weekend or next I can give it a try. Will let you know how it turns out.
Terry
05-12-2002 17:39:20
Also check your ignition coil if you don't have a magneto on this tractor. Sounds like it has been switched to 12 volt, but the coil should tell you for sure.
jerry Gerthofer
05-12-2002 15:47:31
yes it,s 6 volt pos ground. sounds like someone switched it over to 12 volt.i would keep it 12 volt all ready.just slip in a 12 volt battery make sure you have a correct 12 volt regulator hooked up right,it should be a quick starting sys
john holcomb
05-12-2002 08:36:01
yes it is most likely a positive ground unless the generator is stamped otherwise. The starter really dosen't care about the voltage it just runs faster on 12 volt. However if you have 6 volt lights the bulbs will pop as soon as you turn them on with 12 volts. If the generator is putting out 12 volts and you use a 6 volt battery you will cook the battery in short order. good luck, John
