Will 88 Hydraulics Work On A 77?
Ross
05-10-2002 21:46:53
I have a hydraulic pump off an 88 but will it work on a 77? If it will, what do I have to do to get it to work on a 77 without hydraulics? Thanks, Ross Boots -MI-
Mike Ky
05-11-2002 07:26:04
 Re: Will 88 Hydraulics Work On A 77? in reply to Ross, 05-10-2002 21:46:53
The hydraulic housing and pump are the same on an 88 and 77. If 77 had a manual lift on it,you will need too remove the drive gear and cut the input shaft on the transmission off so the hydraulic pump will go into the transmission case.
Ross Boots
05-11-2002 11:49:27
 Re: Re: Will 88 Hydraulics Work On A 77? in reply to Mike Ky, 05-11-2002 07:26:04
Hey thanks, I was wondering why the pump wouldnt drop down in there, I thought that shaft looked too long to let the pump set in there. Thanks Again!! Ross
