Super 55 Diesel Fuel Pump
Pete in Post Fa
05-08-2002 21:54:23
My tractor came to me with an electric fuel pump installed. It now has ceased to function.
Is the pressure different for a diesel fuel pump than an HC fuel pump? Volume?
I replaced the installed electric fuel pump with a new electric fuel pump for an automobile.
Using starter fluid the tractor would try to start but would sputter out very quickly. Sorta like it was running on the ether and was getting NO fuel.
Any ideas?
Pete in Post Falls
Pete in Post Falls
05-09-2002 21:10:48
 Re: Super 55 Diesel Fuel Pump in reply to Pete in Post Falls, 05-08-2002 21:54:23
Is was air locked all right.
As soon as I bledt the air out of both filters, she started up, sputtered and fired up!
Thanks for your inputs
Pete in Post Falls
pete in Post Falls
05-09-2002 10:20:16
Driving to work this morning, I had a thought. If I ran the tractor out of fuel, could the fuel filters be empty and full of air, causing a vapor lock? or just empty and no fuel is getting to the injector pump yet?
I'm gonna try to check output of the filters/Injection pump before I go too crazy!
More to follow....
Pete in Post Falls
Kevin
05-09-2002 17:04:33
 Re: Re: Super 55 Diesel Fuel Pump in reply to pete in Post Falls, 05-09-2002 10:20:16
Yep, air has to be purged as your first step.
Most fuel pumps have enough pressure to keep a diesel running, but a real cheap one might not output enough pressure.
ken
05-09-2002 11:24:26
check polarity on wiring for pump, maybe wired backward so not pumping. hope this helps
Mike (WA)
05-09-2002 07:48:09
I replaced the original pump on my 550 with a universal type electric pump from NAPA. It has always worked fine. I wonder if your pump is just not working properly?
