880 3pt
Mark
05-07-2002 20:03:34
1958 880 single cylinder slowly lowers after lifting 3 pt. I bled by loosening one hose fitting, cycling ram up & down, then the same to the other hose. Did same for left side auxillary and filled to level. It all worked fine last year. Is the ram in need of new o-rings or am I missing something else? If the ram needs work, anyone have a recommendation on who to take to in southeast or central WI? Thanks for the help.
Mark
Scott Green
05-08-2002 02:52:21
 Re: 880 3pt in reply to Mark, 05-07-2002 20:03:34
Mark , if you are the least bit machanically inclined , take the cylinder apart and do it yourself. Very simple job. After you do one , you'll never hesitate to jump into another one.
