V8 power
Jack Feller
05-07-2002 19:20:30
I have wondered for a while about the Oliver 2255 versus the Massey 1150. These were both good tractors of their days but I believe I've heard more horror stories about the Perkins than the Cat. Many people pull the Massey's around where I live. Noone pulls the Oliver. I believe it could be some major competition to every color tractor. Which do you all think is the better all around tractor. Which engine do you think could be built for more power? Thanks
m kuhns
05-08-2002 05:09:03
 Re: V8 power in reply to Jack Feller, 05-07-2002 19:20:30
The 540 or 510 Has the better bottom end with 4 capscrews per main. A weak point with the 540, 510, and 640 are the dry sleeves not to mention the heads on the 640 only. The dry sleeves will break off the thin top ridge and go into the oil pan ruining the crank for sure. The best fix for this is getting rid of the sleeves and putting in a larger piston in any of the perkins engines. We pull a 2805 MF with a 640 and valve seats keep dropping out on the exhaust side. The 540 and 510 the seats are rolled in place and haven't heard of and problems with the 540 or 510. I would like to put one together also with 3208 in the future. The bottom end isn't quite as heavy though. It only has 2 bolts per main but I think I could tell you where to get a girdle if need be. Cat runs 350Hp through these in marine applications where you can keep them cool with seawater and stock fuel system. Somewhere between 450 - 500 Hp should be easy with the right changes to the engine and plenty of boost. If you start running this hp, either tractors' "torque" won't hold up to Hp, so you will need to be looking for more gears for more tire speed. I would get rid the the torque in either tractor and put a drive shaft in its place. I would think the rears in the 2255 or 2-180 would possibly be a little heavier than the 1155. It is all up to you to decide, but an overhaul kit for a 540 is around $2200 compared to $750 for the 3208 636 cubic inch Caterpillar. The 640 perkins is even more expensive at $7500 just for parts for the kit.
