310 oil pan modification
Brad WI
05-06-2002 20:12:27
Does anyone know of a shop in Wi that would be able to enlarge the sump on my 1855 oil pan(310 no cooler)? I would like to add about a gallon to it.I don't have the oil cooler and I've heard this helps.the tractor doesn't see much heavy work but the engine is fresh and I want to prevent any mishaps i can. also my oil pressure holds about 50-55 lbs for about 1/2 hour then drops to about 25 when warm,i remember seeing a post about the same subject,but i couldn't find it. any advice would be greatly appreciated thanks
WFE
05-07-2002 09:44:28
 Re: 310 oil pan modification in reply to Brad WI, 05-06-2002 20:12:27
Brad,
Any good welder or machine shop can enlarge your oil pan. Depending how particular you are, you can simply have them cut the bottom out of your existing pan, bend some steel to fit between your now two halves, and reweld it together with the spacer in between to enlarge the sump. Or you can go get an oil pan from a salvage yard and they can make one large one out of two. It does indeed help the engine if you are going to adhere to the original 100 hour service interval on the engine oil. On my 310s without an enlarged pan, I change the oil at 50 hours instead of 100, but they all have the oil coolers to keep oil temp down. Since you don't the larger oil pan capacity will keep your oil temp within reason and allow you to maintain the 100 hour interval if you want. Of course, oil is cheap. Your oil pressure sounds normal. I would not be concerned about maintaining 25 lbs at operating temp. Remember that oil flow is more important than pressure. You only need enough pressure to ensure that oil is being pumped up to the turbo. If you want, however, you can increase the pressure in the main oil gallery by adding a small shim to the oil pressure regulating spring at the front, right hand side of the block about 3-4" below alternator mounting. Hope this helps and best regards,
WFE
Brad Wi
05-07-2002 16:44:47
 Re: Re: 310 oil pan modification in reply to WFE, 05-07-2002 09:44:28
thanks for the info on the oil psi.makes me feel a little better about the motor!I'll try a welding shop for the pan, just to make sure it looks nice.
