Oliver 550 serial number
RandyS
05-05-2002 20:12:41
I can't find the serial number on my new 550 is there any way I can determine the year by the number cast in the engine block?
Rand
B A Star
05-08-2002 15:50:44
 Re: Oliver 550 serial number in reply to RandyS, 05-05-2002 20:12:41
You should have three rows of characters cast as raised letters and numbers on the LH side of the crankcase. As an example, my engine has: 180 220-G 1LB-100 B 1068 Top row Waukesha part number, middle row Oliver part number, bottom cast date: October, 6,1958. Remember that the crankcase and cylinder heads were cast in Charles City and some machine work performed, then sent to Waukesha, Wisconsin for assembly into a complete engine, then shipped back to Charles City for installation in a tractor. The above engine is in a 1959 production tractor. The part number 1LB-100-B is what is known as a prime part, in other words a bare crankcase. The part number that the dealer ordered was 1LBS-100-B, the "S" indicates an assembly including other parts such as main bearing caps, camshaft bushing and etc.
ShepFL
05-08-2002 06:58:05
I doubt you would find something based on casting on block. Some of the other fellas BA Starr and the like should be able to.
My 550 did not have s/n tag, but it was stamped on the RH side of engine on vertical boss below generator. Check there. HTH
