GM 4-53
Alberta Dave
05-01-2002 08:44:29
I have a just bought an 1850D for parts. The engine is out and needs new sleeves. I have another 1850 that sufered some type of engine anomally last year(either an blown head gasket or hole in piston is my best guess)I plan to rebuild the engine. I also have a line on a 4-53 out of a 1950. It is available with the bell, clutch Hi/Lo attached and apparently runs. The previous owner had it cranked up to 135HP with bigger injectors but blew out the transmission on the 1950.
My questions are:
1) will the 4-53 bolt into 1850 tub?
2) will the rad be adequate to cool the 4-53?
3) how expensive are parts for the 4-53?
4) have I missed any big points?
5) why is the theme from Deliverance called "Duelling Banjo's" when its really one banjo and one guitar duelling?
glenn
05-03-2002 12:25:12
 Re: GM 4-53 in reply to Alberta Dave, 05-01-2002 08:44:29
135hp thats very hard to beleive,with just replacing the injectors.
Larry from Maryland
05-01-2002 18:32:30
1 the 453 will not bolt into the 1850 tub without a lot of cutting and welding.2 yes 3 still easy to get.4 yes get a 453 tub or get a massy 510 combine engine.
rednekelmo
05-01-2002 14:56:39
1-4 no help
5 it's dueling banjo not banjos so i believe it's because the banjo it dueling with the guitar.
hope you like listening to the scream of the old 2cycle detroit
