Howdy,... You just clean it as needed, wire brush it, and tape up the rubber around the windows. Just clean it good and paint it inside and out. Clover White. The new headliner is expensive from AGCO, (Around $200.00) but you can use some really heavy weight carpet padding to use. Really cheap! But you have to remove the cab top to put it in correctly, so it blocks up the air flow. Otherwise it doesn't take air through the heater core, just around it. There are 4 bolts that hold it on, 2 in the front inside facing upward, and 2 in the rear facing upward. Then you need something to lift the cab roof off. The headliner is glued to the roof, and you can put carpeting on it facing downward. Makes it nice and quieter. You can glue carpeting to the inside of the cab on the fender wells and make nice armrests,... But it is not advisable if you are working the tractor. It's hard to clean, but looks really nice. Just fix the wiring as needed, and do what ever else that needs to be done. Really makes it look good, and then you will have a sharp looking interior. Hope this info helps.
