Oliver 99 Questions-For Newcomer
Pappy
04-20-2002 15:05:53
I have located an Oliver 99 for sale to far from me to run over and look at. Before I go, would you help me with information?
What years were they built?
Are they available in gas or diesel?
What is the horsepower?
Is this a six cylinder?
What is the approximate weight?
Many Thanks? Pappy
Ken Williams
04-20-2002 19:37:43
 Re: Oliver 99 Questions-For Newcomer in reply to Pappy, 04-20-2002 15:05:53
Pappy, The original Oliver 90-99s were built between 1937-1952. They were powered with a 4 cylinder gasoline engine, that produced about 54 hp on the pto, and about 41hp on the drawbar. It had 4 speeds forward and 1 reverse. It weighed about 7300lbs. In the years 1953 and 1954 Oliver came out with a styled 99 that had a 6 cyl, 302ci engine, available in either gas or diesel. The transmission still retained the 4 speed. From 1954 to 1958, Oliver built the S99, that used the gas or diesel 302ci engine, and also offered the 3-71 General Motors diesel engine. The transmission was also upgraded to 6 forward and 2 reverse gears. Withe the 3-71 engine, the pto hp was now 78hp, and the drawbar hp was 59hp. The weight was about 10,000lbs. I hope this helps you, and congratulations. Any version of the Oliver 99, is a fine tractor to have.
