Oliver 60 seals
Pete in Ks
04-19-2002 09:53:31
I noticed some seepage around the axles on my Oliver 60 while preping for paint. So I might as well fix it now. Are these seals felt material? Also the wiring is a mess. Is there a quick way to tell if it is a Pos. or Neg. ground? I'm sure it was Pos. ground from factory but it isn't as it once was.
Lee W
04-19-2002 10:20:31
 Re: Oliver 60 seals in reply to Pete in Ks, 04-19-2002 09:53:31
The parts book shows a felt seal and a regular seal. The seal part No. is H1443 and the felt is H703. I would think it would be postive gound. Harry at G&R might have one of the seals in his back pocket. Hope this helps.
Geoffrey
04-20-2002 21:28:00
 Re: Re: Oliver 60 seals in reply to Lee W , 04-19-2002 10:20:31
I've had the same problem with my 60 even after puting new seals in. I finally took the end cap off and put silicone between each of the shims and the carrier and cap. It seemed to work for now.
