Who made the Oliver MFWD front axle?
Jim Meade
04-17-2002 10:13:29
I'd like to find the manufacturer of the Oliver 4WD front axle assembly they put under the 2255, 1850, 1650,, 1600 and 1955. Same one (I think) unfder the 2-85, 2-105, 2-110.
I'd trying to buy an axle assembly for less than $1900.
Mick
04-17-2002 11:20:17
 Re: Who made the Oliver MFWD front axle? in reply to Jim Meade, 04-17-2002 10:13:29
Jim,
I believe it was Clark, who built this unique
MPFA for Oliver, beginning in 1962. Oliver was
on the cutting edge, with 1800, 1900 & 1600
models equipped w/PFA. Basic care kept them
running strong. good luck.
Hey Mick
04-19-2002 07:21:53
 Re: Re: Who made the Oliver MFWD front axle? in reply to Mick, 04-17-2002 11:20:17
Maybe you should look at Minneapolis-Moline tractors. The M504 G704 G706 G708 all had 4 wheel drive. You could get it as an dealer installed option on the GBD, GVI MH95 and MH97.
Jim Meade
04-17-2002 13:33:04
Others confirm your suggestion that it was Clark. Thanks. I was going to try to go to them to get an axle, because White wants $1890. Instead, I went to O'Brien Implement in Sheldon, IA and they are offering an assembly in which a u-joint replaces the dogbone and balls for $750 exchange. I'm going to try it.
