JD rims on Oliver hubs
Jeff Oliver
04-15-2002 20:02:06
I just bought a set of 15 inch JD rims to put on my RC 88. From what I can see they should bolt right up to my Oliver hubs. Am I right or will I have to modify something?
dubie
04-16-2002 20:02:51
 Re: JD rims on Oliver hubs in reply to Jeff Oliver, 04-15-2002 20:02:06
As long as they are the older 9 bolt pattern they should bolt up.
dubie
04-16-2002 20:02:47
Scott Green
04-16-2002 06:04:00
Jeff , Almost daily , I drive past a bigger Oliver tractor , which has John Deere yellow rims on it. Years ago a tractor salvage yard man told me that a lot of these tractor rims are made by the same manufacturer. The tractor companies didn't make there own rims. So , the chance of you putting John Deere rims on your Oliver might be good.
meant to say ....
04-16-2002 02:55:54
I am sorry I meant to say 38 inch rear rims thatare 15 inches wide. yes it is an Oliver 88 rowcrop and not a standard.Everything looks like I will be able to take one set off and bolt the other set on without welding any lugs on but I was not sure .
Alberta Dave
04-15-2002 21:42:22
I am not familiar with the RC 88 but I assume it is what I call a Oliver 88. I have a 770 Oliver that will accept rims from a 4020 John Deere. In fact my 770, 1650 and 1850's all take the same front rim. I can buy new jobber rims from most parts dealers for about 1/2 of what the Agco list is.
