S77 Shims
Jim
04-15-2002 17:16:42
I just put a new outer and inner bearing on the left axle of my S77. It is back together but I just remembered someone had once told me that you have to get the right amount of shims on the end of the axle so there will not be to much pressure against the bearing. Is this true? If so, how do you tell how many shims are needed? The tractor has 3 shims on it right now. Thanks in advance.
WFE
04-21-2002 18:55:02
 Re: S77 Shims in reply to Jim, 04-15-2002 17:16:42
Jim,
After rereading the above posting, substitute wheel center for bull gear. The string gets wrapped around the bull gear to determine pounds of pull with the cast wheel centers off the axle. Sometimes I think faster than I can type. Sorry and best regards,
WFE
WFE
04-15-2002 18:05:08
If you have access to or can get a shop manual from a dealer, it will explain how to determine the correct number of shims. But here goes a brief description: Before you install the bull gear on the axle, measure the bearing preload by the following: Fasten a string to the axle and make quite a few wraps around the axle. Connect the other end to a spring gauge which will measure pounds of pull. With some shims assembled and hardware tightened on the seal cover (but bull gear is still off the axle) pull the spring gauge until the axle begins to move. There should be approximately 10-15 pounds of pull required to begin turning the axle. If you have less than that, add a shim at a time and use the above procedure again to get the correct bearing preload. If it requires more than 15 pounds to turn the axle, remove one shim at a time until you are to spec. This is time well spent as bearing preload is quite important in transmissions. Good luck.
