Oliver 80 water pump seal
Wayne
04-14-2002 19:08:41
Looking for the seal for water pump on a 80 oliver or what can be used to make one. Also inside the bottom radiator hose there was what seemed to be some sort of baffle to restrick the flow of water, does this sound right.
Terry
04-15-2002 16:27:04
 Re: Oliver 80 water pump seal in reply to Wayne, 04-14-2002 19:08:41
The 80 uses a rope packing for a seal. Just back off the gland nut around the fan shaft and repack with rope packing from a plumbing supply house. Try to get graphite packing instead of the new rubber stuff. Also the lower radiator hose has a coiled spring inside to keep the hose from collapsing. Not a restricting baffle. Hope this helps.
