I have oil in my antifreeze in my cockshutt 1650 gas
Jaarno V.W
04-07-2002 22:29:59
i have purchased a cockshutt 1650 gas. After running it for the first time i've owned her, I checked it over and found oil in my radiator. i think it may be the head gasket. does anyone have any thoughts on this?
PLEASE HELP! Thanx:j.v.w
Larry from Maryland
04-08-2002 10:08:23
 Re: I have oil in my antifreeze in my cockshutt 1650 gas in reply to Jaarno V.W, 04-07-2002 22:29:59
That usually means you have cracked block.The water is preasurised and needs a higher preasure to push the oil into it,so that means the block or hydro power cooler.
It's time to through in the towl.
04-08-2002 09:08:24
Bob M
04-08-2002 05:37:28
If your 1650 is equipped with a 2 speed hydrapower, oil could also be coming from a leak in the hydrapower oil cooler. Can you sample the oil in the cooling system? If it's engine oil you probably have a bad head gasket. If it's auto tranny fluid, the leak's in the hydrapower cooler.
