Oliver 60 1948
Dave
04-07-2002 16:40:51
I have resently put new rings,rodbearings and a valve job on my 60. But it still rattles . The ristpins check out very good. Anyone have any ideas of what could be wrong? Thank you,Dave
Jeff
04-09-2002 01:26:52
 Re: Oliver 60 1948 in reply to Dave, 04-07-2002 16:40:51
Dave, check the front crankshaft pulley for slop in the rivets. That will make it rattle. Jeff.
Dave West
04-07-2002 18:56:03
I bought rings and bearings from a place in Moline Mi.I will get there Phone # on Monday. I had the noise in the engine before I rebuilt it . I would think the valves would be ok. Not shure about the Cam.I did check all the rods but not the mains. I guess I'll just pull the eng and do it all .Then I'll know.I'll get back to you Monday night.Thanks,Dave
Phil
04-07-2002 18:36:41
Did you check or do anything with the crankshaft? Did you double check your valve lash adjustment.
Where did you purchase your engine parts? I haven't checked; are any available thru Agco? I have a "47" 60rc that's locked up. The top and bottom of the cylinders look good but the rings are rusted to the cylinder walls. I will be needing engine parts soon.
