Split open my Super 55
Paul Stanley
03-07-1998 15:24:01
My Super 55 is split open to get a new main seal for the tranny. Anything else I should do as long as I am in there? Everything else looks good. I also fixed the rad, it had a small leak. Unfortunately, I am not doing the work. I tore down my garage last year and was going to rebuild this summer and I have no covered work area.
JEFF RZEPKA
03-09-1998 06:38:13
 Re: Split open my Super 55 in reply to Paul Stanley, 03-07-1998 15:24:01
: My Super 55 is split open to get a new main seal for the tranny. Anything else I should do as long as I am in there? Everything else looks good. I also fixed the rad, it had a small leak. Unfortunately, I am not doing the work. I tore down my garage last year and was going to rebuild this summer and I have no covered work area.
CHECK THE ENGINE REAR SEAL, THROWOUT BEARING, CLUTCH
THE PTO SEALS ARE ALSO EASY TO DO AT THIS TIME.
WHATEVER YOU DO, DO NOT SPRAY THE PTO CLUTCH WITH ANY CLEANER LIKE I DID AND EAT THE OIL SEALS INSIDE AWAY.
JUST LOOK AROUND IN THERE FOR WEAR
JEFF
Paul
03-09-1998 20:27:21
 Re: Re: Split open my Super 55 in reply to JEFF RZEPKA, 03-09-1998 06:38:13
Thanks for the tip. I probably would have cleaned up my pto clutch just like you did.
Paul
