Hydraulic System Oil Change
Super 55
Pete in Post Fa
04-01-2002 07:16:02
Yesterday I changed the oil in my S55, finally.
Drove it around and used the 3pt with blade to move some rocks.
Lots of oil leaking from the Cross shaft seals.
I used the specified 10W30 engine oil, but have not changed the filter.
I changed the oil cause it was milky (water?) and has been for some time. I have noticed that the seals have seeped before. My plan is to try to find the filter and replacement seals and replace then soonest.
Am I missing anything here?
Pete in Post Falls
Jake
04-01-2002 09:07:25
 Re: Hydraulic System Oil Change - Super 55 in reply to Pete in Post Falls, 04-01-2002 07:16:02
If you put 30 wt oil tn the trans [5 gal] no wonder the seals are leaking it takes 140 wt in the trans, the filter has nothing to do the trans. There are TWO tanks in the trans, front filler takes the 140 wt, the rear filler takes 6-9quarts. To drain the hydraulic system take the pipe plug from the 3 bolt cover on the right front of the top cover, put a 3/8 hose on a pipe nipple, start the engine and the oil will pump out. The cross shaft seal are replacable, take all levers etc off, a sharp chisel driven into the seal will pry it out and the new driven in. About a 3 hr job.
Pete in Post Falls
04-01-2002 10:23:40
 Re: Re: Hydraulic System Oil Change - Super 55 in reply to Jake, 04-01-2002 09:07:25
I didn't put the 30 wt into the trans, but into the 3pt hydraulic system.
Thanks for the info on the seals!
Pete in Post Falls
Larry from Maryland
04-01-2002 09:04:37
The milky white oil will be thicker than the new oil,thats why it did not leak out so fast.Have you fixed how the water got in there?
Pete in Post Falls
04-01-2002 10:26:07
 Re: Re: Hydraulic System Oil Change - Super 55 in reply to Larry from Maryland, 04-01-2002 09:04:37
Kids removed the cap as a keepsake I guess and rain got in.
All replaced now.
Thanks
Pete in Post Falls
John P.
04-02-2002 09:38:45
 Re: Re: Re: Hydraulic System Oil Change - Super 55 in reply to Pete in Post Falls, 04-01-2002 10:26:07
Hey Pete, does your Super 55 have the older style 3-point hitch filter that sticks out the left side under the seat, or is it the newer style filter that points out the front of the 3-point system?
Pete in Post Falls
04-09-2002 07:00:51
 Re: Re: Re: Re: Hydraulic System Oil Change - Super 55 in reply to John P., 04-02-2002 09:38:45
Sorry it took so long to answer, I've been vacationing!
The one that sticks out the left hand side. Checking around it appears to be a gas filter used as an oil filter.
Pete in Post Falls
