Super 55 pto question
dave westlund
03-31-2002 17:35:20
I was looking at a super 55 today. There is a lever that slides along side the right fender. Is the the lever to engage the PTO? I moved the lever,but the PTO did not stop. Or is there another lever that I did not see?
thanks Dave
Pete
03-31-2002 18:46:39
 Re: super 55 pto question in reply to dave westlund, 03-31-2002 17:35:20
Dave
That is the PTO lever - most of the PTO's "creep" even after the PTO clutch is disengaged - you should be able to feel the cams go "over center" when engaging the PTO - If the adjustment is right!
Best way to check is to put a load on the PTO.
Pete
Kevin
04-01-2002 13:25:27
 Re: Re: super 55 pto question in reply to Pete, 03-31-2002 18:46:39
My PTO disengages completely, but not until you push it that last little 1/2 inch forward.
jake
08-29-2003 03:55:39
 Re: Re: Re: super 55 pto question in reply to Kevin, 04-01-2002 13:25:27
Dont push the lever forward to far ther is a roll pin in the rear of the tractor that can break which holds in the shaft that drives the pto. If you break that pin all your clutches will come out of the basket tearing them. most all pto creep some.this problem is quite common and should only cost you $600
