1600 Questions
Andrew
03-30-2002 16:00:45
I just bought my first Oliver and have a few questions. Please excuse my ignorance as I am "green" when it comes to Olivers.(pun intended)
I've been using IH euipment so I have a bit to learn.
On the ID tag below the instrument panel is the following information. 16-2512
145 304-612
The tag is faded so all that can be read are the stamped numbers. What exactly are these numbers? I am guessing the serial number is 145 304. Is that correct? Is it a 1964?
I don't have an operator's manual yet and would like to know what the two idiot lights are on the dash. The light on the right flickered for a bit the first few times I ran it and is now on all the time. All the fluid levels are OK. The only gauges are fuel, temperature and tach. I am guessing the idiot lights are oil pressure and charging system but could be wrong.
By the way, it's gas with a WF.
Thanks,
Andrew
Don
03-31-2002 20:14:26
 Re: 1600 Questions in reply to Andrew, 03-30-2002 16:00:45
you have the lights right, and the one that is lit would be the amp light, which means the generator isn't charging. If you can, take it in to a shop that rebuilds starters/generators/ and alternators. Where are you located?
Don
Andrew
04-01-2002 03:29:47
 Re: Re: 1600 Questions in reply to Don, 03-31-2002 20:14:26
Don,
Looks like the voltage regulator has been replaced recently. Like you say it may be the generator and the previous owner tried the regulator as a fix. There's a shop here in the Cleveland, Ohio area that has done work for me in the past. When I get a chance I'll take it in and have him test it.
Thanks,
Andrew
