Oliver 550 Power Steering Unit Specifications
Mike B
03-26-2002 11:44:39
I am presently trying to rebuild the Char-lynn PS unit on my 1959 550 Oliver. It is the type that is direct coupled to the steering box (part S105-D). Trouble is, I am missing the input and output shafts inside of the gearmotor (someone had created a shunt shaft). One of the needed "dogbones" has splines on both sides, the other has a spline and a slot on the other. I have researched and spoke to several sources including Force America, but none can provide detailed original specifications such as the length of the shafts and number of and diameter of the splines so I can try to match them with modern parts. Thus, I am hopeful that someone has these old parts laying around, or has some direct experience in crossing them with modern parts. Any help would be extremely appreciated.
