Price for a 77 row crop
Shawn
03-23-2002 20:48:43
A friend of mine has a 77 row crop narrow front that he wants to sell me but has no idea of a price he wants. I was wondering if you guys could give me an idea of a fair price. The tag is missing that has the serial number so we don't know the definite year of the tractor. I think it is a later one just by the decals. He says that the tractor will run but that the motor has a definite ticking sound. The sheet metal is fairly decent and supposedly he does have the side curtains for it but, I haven't seen them. It will need new tires all around as the ones on it are badly cracked & flat. It doesn't have the original seat and will probably need a battery. I wouldn't mind having it but would hate to put alot more money into it than it is worth. The engine noise is what concerns me the most.
Thanks in advance!
jerry Gerthofer
03-24-2002 17:21:56
 Re: Price for a 77 row crop in reply to Shawn, 03-23-2002 20:48:43
sounds like she saw her better days..... offer him $500.00..... ....
oliver farmer
03-24-2002 16:40:04
is it a gas or diesel. as far as the year,between 1948 and 1954, is when they made the fleetline tractors.1954 to 1958 are the super years. the fleetline tractors have no "flat plate" with bolt holes on the frame. they also have the full louvered side panels on the fleetline tractors and the supers have the side panels "cut out" for the engine maintance. now, if you can get to it, look on the right side of the engine block in front of the distrubutor. the year will be cast in it. if it runs , the gas will be worth 400to 600, the deisel will be worth 500 to 800. it depends on what shape the gages are in, if it has the original switch, and if it has fenders and lights that are original. the pricing is ONLY my opinon and other people have there own . hope this helps, if you are not interested, let me know where you live.
Jeff
03-23-2002 21:00:43
Shawn, the engine noise probably isn't something major. The valves probably just need an adjusting, which is something easy to do. Being that the tires are flat, that brings the value of the tractor down considerably. See what the cheapest price you can get it for is. Does it have cast iron wheel centers on the back or are the wheels pressed steel? Does it have hydraulics? Is there a lot of oil on the engine? Do all the gears work? Is there paint on it or is it mainly rust? These are some things to take into consideration. I would say somewhere in the $400 range would be good being that the tires are flat. Jeff.
Shawn
03-23-2002 22:04:37
 Re: Re: Price for a 77 row crop in reply to Jeff, 03-23-2002 21:00:43
The tractor does have the cast rear wheels (38"?), Sheet metal doesn't appear to be too rusty. There is oil on the motor and it does have the hydralics. Haven't been able to try the gears because it is buried under a bunch of stuff in the guy's shed. Pto lever has been cut down.
Shawn
03-24-2002 20:08:09
 Re: Re: Re: Price for a 77 row crop in reply to Shawn, 03-23-2002 22:04:37
Thanks for all your advice on this issue.
Shawn
