Switching from Hydra-power to Over-Under on 1850
Steve
03-23-2002 08:23:31
I am relatively new to Olivers. I have been looking at a few 1850's and was wondering if it is possible to convert an early 1850 from hydra power to the over-under used in the late 50's and 55 series? This may not be feasible but I am curious. Thanks. Steve
Larry from Maryland
03-23-2002 09:45:33
 Re: Switching from Hydra-power to Over-Under on 1850 in reply to Steve, 03-23-2002 08:23:31
It can be done. The bigest differance is the 3 speed has a oil cooler in front of the radiator,and the 2 speed has a heat exchanger cooler siting ontop of it.The shift linkage is differant too.If you have a doanar tractor its easy to switch everything.You can get or make what you need if you don't have the spare tractor.
