Oliver70
flash
03-21-2002 15:36:55
does anyone know if oliver used another engine other than the continental in the 70 gas, my after market parts book seems to indicate that.
Larry
03-21-2002 18:23:53
 Re: oliver70 in reply to flash, 03-21-2002 15:36:55
The engines look differant in that the distributor comes out on one side and the mag engines have those on the other side driven by a shaft.My oliver parts book shows 5 versions of the same engine.
flash
03-21-2002 19:25:05
 Re: Re: oliver70 in reply to Larry, 03-21-2002 18:23:53
thanks for the info but you didn't say if the others were continentals or not!
Larry
03-22-2002 09:15:04
 Re: Re: Re: oliver70 in reply to flash, 03-21-2002 19:25:05
All continentals.
Terry
03-21-2002 16:37:26
All of the 70 engines were basically the same. The earlier engines 1935-1939 used an engine with 5 timing gears on the front of the motor, and the later ones(mid1939-1948) used an engine with 3 timing gears. This was about the only difference, other than some of the later engines used a little larger bore.
