Rebuilt Engine for Oliver 1650 Diesel
Jeff
03-20-2002 14:48:50
I'm looking for a source to buy a rebuilt engine for my 1965 Oliver 1650, serial number 1652252.What should I expect to pay for a rebuilt engine?
Honkey
03-23-2002 12:50:11
 Re: Rebuilt Engine for Oliver 1650 Diesel in reply to Jeff, 03-20-2002 14:48:50
Your oil pressure problem can be fixed by rolling in a new set of main bearings. The fuel out the exhaust is most likely due to a bad injector. I would take them all out and have them re-set and tested. That should fix you up in good shape!
Most likely the reason you can't find a shop to fix it is because they charge so much labor that it is cheaper to put a rebuild in. It's happening everywhere not just in Florida!
I'm sure you can handle a job like this yourself. Don't feel intimidated by it, after all, if you get in a jam, you can get just about any help you need right here!
Good luck
Matthew in SD
Big Jim
03-22-2002 14:02:38
Jeff,
Wouldn't you better off rebuilding the engine you already have? If the block isn't damaged you can rebuild just about everything else in them and then you know that you have a good engine. My .02 worth.
Jeff
03-22-2002 14:30:41
 Re: Re: Rebuilt Engine for Oliver 1650 Diesel in reply to Big Jim, 03-22-2002 14:02:38
I'm located in central Florida and the few shops located near me really don't want to get involved with rebuilding a Wakausha. It's actually interesting to hear some of these southern boys try to pronounce Wakausha. If you know of a good shop within 300 miles of me(I'm 90 miles north of Orlando) please let me know.Thanks
Bill
03-21-2002 17:01:42
No, they don't all do that. I own a MM G750, the same thing as the 1650 Oliver. It has close to 7000 hours on the motor and still is running strong.
Matt
03-20-2002 18:04:05
what is wrong with your old engine?
Jeff
03-20-2002 19:09:51
 Re: Re: Rebuilt Engine for Oliver 1650 Diesel in reply to Matt, 03-20-2002 18:04:05
At 4900 hours it's blowing alot of unburned fuel out the exhaust. The oil pressure is good at start up but as the engine warms up drops off to about 12 psi under load and barely registers at idle.
jerry Gerthofer
03-21-2002 11:09:56
 Re: Re: Re: Rebuilt Engine for Oliver 1650 Diesel in reply to Jeff, 03-20-2002 19:09:51
that must be a waukeshaw. right..... .....
Jeff
03-21-2002 12:19:39
 Re: Re: Re: Re: Rebuilt Engine for Oliver 1650 Diesel in reply to jerry Gerthofer, 03-21-2002 11:09:56
You're right it is a Waukeshaw. Do they all suffer from this problem? I'm told mine is a cross-fire model, does this make any difference?
jerry Gerthofer
03-21-2002 17:30:42
 Re: Re: Re: Re: Re: Rebuilt Engine for Oliver 1650 Diesel in reply to Jeff, 03-21-2002 12:19:39
pretty much.they were a poorly built engine.and just did not hold up long. onless they were completely rebuilt.with the new waukeshaw updated engine kit. had it done on my 1655 several yearsback..now it has a engine that won't quit
Tim
03-21-2002 19:40:48
 Re: Re: Re: Re: Re: Re: Rebuilt Engine for Oliver 1650 Diesel in reply to jerry Gerthofer, 03-21-2002 17:30:42
You know I guess your right Mr. Gerthofer
my 1969 model 1650 has not run but 33 yrs
so far Oliver should be ashamed of such
a short life engine! Now to be serious, that
283 waukesha in a 1650 1655 and 2-70 white
is one of the best little diesel engines ever
made. thanks
