995 Lug-o-Matic
Gary
03-19-2002 13:06:06
Tell me about the Oliver 995 Lug-0-Matic?
Gary
03-20-2002 05:38:20
 Re: 995 Lug-o-Matic in reply to Gary , 03-19-2002 13:06:06
The torque converter which was used in the 995 had several stages. This let the tractor go through a tough spot and the engine speed would stay the same.When the load lightened your speed would go back to match the gear you are in.
Terry
03-19-2002 16:23:53
The 995 lugamatic was the deluxe version of the 990. They both use the same 371 Detroit diesel, but the 995 has a fluid drive torque converter in front of the transmission.
MIKE (WA)
03-19-2002 18:47:36
 Re: Re: 995 Lug-o-Matic in reply to Terry, 03-19-2002 16:23:53
I had previously thought that the Lugmatic ended up being something akin to the IH hydro's- set the engine at optimum RPM, then vary the speed of the tractor with the hydro. But is that right? If it's just a torque converter in front of a conventional transmission, what's the advantage? Seems like it would be just another source of power loss. Someone in the know please comment.
brian
03-19-2002 19:44:09
 Re: Re: Re: Re: 995 Lug-o-Matic in reply to Mark, 03-19-2002 19:17:27
sounds like a case-o-matic transmission. Same concept
brian in ky
Gary
03-21-2002 06:47:32
 Re: Re: Re: Re: 995 Lug-o-Matic in reply to Mark, 03-19-2002 19:16:44
Is the 995 lugomatic a hard tractor to come by and what would be a resonable price for one that is in good shape?
