Super55/550 3pt lift rocker / rocker pin woes
Mark
03-17-2002 13:39:24
I'm working on the hydraulics on this tractor, and since it seems to have sat out in the rain for 40 years, of course everything is in terrible shape. The lift rocker is mangled, the position control bolts are rusted, the linkage pin is rusted, and worst of all, the main rocker pin in the top casting is frozen in place. Does anyone know a good way to get this pin out? Some previous owner has peened the ends over trying to get it out. It never budges. I've tried beating, heating, and the wax candle trick to no avail. Is there anything else I can do short of taking the top casting off complete and rigging up something in the press to press this pin out? I am already pretty sure I will have to destroy this pin and get another as well as a lift rocker. In case you have parts you want to sell, check my want ad in the classifieds.
Thanks for any help!
Mark
Keith Martin
03-20-2002 09:53:30
 Re: Super55/550 3pt lift rocker / rocker pin woes in reply to Mark, 03-17-2002 13:39:24
I had the same problem just a few weeks ago. I know my tractor sat out for five years. First you are going to have to grind down the mushroon (I was lucky, I only had one end that was bad) If you have some one who has a torch AND a large air compressor with a impact hammer. It took well over a half hour of heat before it broke loose. it took another half hour driving it back and forth before it came out. I wound up having to take the whole Hyd. pump section off because I was working on the motor as well.
Mark from Genoa
03-17-2002 16:49:43
I had the same problem with that pin. I ended up drilling the entire pin complete out and using a hack saw and a dremel tool with a metal cutting bit to remove the last portions. Good luck, it took me a couple of weeks to get it out. Only to remove the hydraulic cover and find gear teeth in the bottom of the transmission case.
