Super55/550 External Hydraulic Casting
Mark
03-17-2002 08:59:09
I recently purchased a triangular shaped casting used for adding external ports for a Super55/500 tractor for a tractor I am restoring.
My question is does anyone know which outlet port is the drain and which is the pressure side? Also can plugs be inserted into the port without damage to the hydraulics.
Thanks
Mark
Gary
03-18-2002 07:29:09
 Re: super55/550 External Hydraulic Casting in reply to Mark, 03-17-2002 08:59:09
Do not plug the ports or you will break the pump.If this is the factory triangle casting it is only made to put on if you have no external valve. It is possible to make one that you can ad a valve but has to have a in and out fed though another valve with a relief valve in it.
