OC-3 Serial Number
Steve - NW Ohio
03-12-2002 16:36:29
I have looked for the number on the frame where it should be, no luck. Is there another way to determine the true vintage. (track layout, bearing size, motor number, etc ....)
Any idea's will be appreciated. You can see it on my home page.
jerry Gerthofer
03-13-2002 12:24:00
 Re: OC-3 Serial Number in reply to Steve - NW Ohio, 03-12-2002 16:36:29
looks like late 40.s mabe 49 or 50..... .
jerry Gerthofer
03-13-2002 12:23:44
Esev
03-12-2002 19:46:10
OC-3 serial plate should be on the bell housing on the left side of the tractor if memory serves me right. Early HG's were at the right rear of the frame. There is a casting date on the right side of the engine block, behind the mag which will date the engine. Judging from the solid front idlers in your picture it's an OC-3 (1951-1957).
