Looking for a 70 expert
Esev
03-11-2002 19:08:45
I am about to become an Oliver 70 owner, and I have a couple questions. We believe the serial number says it is a 1938 (222213). My question is why does the serial index give two sets of non consecutive serial numbers for 37, and 38 ? This tractor is equipped with 36 inch rubber, and cast iron wheels. Was that one of the wheel options offered by the factory, or was that another method of converting from steel ? Thank you
Larry
03-12-2002 12:46:38
 Re: Looking for a 70 expert in reply to Esev, 03-11-2002 19:08:45
I looked in my parts book and the tire could have been 11.5-36. This was an option on the row crop tractor. Look and see if on the cast wheel you can find a # B705E, that is Oliver's part #. As for the change in serial #'s that may be when the Hart-Parr was droped from the tractor and the new styling took place.
Esev
03-12-2002 18:07:13
 Re: Re: Looking for a 70 expert in reply to Larry, 03-12-2002 12:46:38
Thanks Larry, I was hoping someone would pull out their parts book for me. I will definatly need to get one soon, as more questions arise. My guess is that the serial numbering had something to do with either the styling or the switch from 5 to 3 gears. I thought by 1938 the unstyled version was gone from the assembly line. Maybe not. This tractor by the way is a styled row crop. Anyone else have any comments about the serial number sequencing ? Thanks
Zeus
03-14-2002 13:43:25
 Re: Re: Re: Looking for a 70 expert in reply to Esev, 03-12-2002 18:07:13
Esev, the official Oliver Corporation Service Manual for the Oliver "70" tractor states that the change from the 5-gear engine to the 3-gear engine was made at S/N 223151 for the Row Crop and 303507 for the Standard and Orchard. It also gives only the following tire sizes for the Row Crop "70" (NOT the Oliver Hart-Parr Row Crop 70): 11-38 rear, 5.50-16 front; however, it immediately then states "refer to the "70" Part List for rear wheel equipment available for Oliver "70" tractors." The serial numbers for the Row Crop models all begin with the digit 2; the Standard and Orchard models all begin with the digit 3; and the Industrial models all begin with the digit 4. By your serial number it appears that you have a 1938 Row Crop.
Zeus
03-14-2002 13:58:05
 Re: Re: Re: Re: Looking for a 70 expert in reply to Zeus, 03-14-2002 13:43:25
PS: The correct serial numbers for the Oliver Row Crop 70 are:
1935 200001-200685
1936 200686-208728
1937 208729-219644 220426-220694
1938 219645-220425 220695-223254
1939 223255-231115
1940 231116-236355
1941 236356-241390
1942 241391-243639
1943 243640-244710
1944 244711-250179
1945 250180-252779
I believe the two sets of different numbers for 1937 are because of the styling change, but not sure. Probably Sherry Schaefer at Oliver Information can tell you.
Larry
03-13-2002 18:13:25
Parts books are really nice for ordering parts but also nice to have if you take the tractor apart to restore it. I bought all my Oliver books from Metzger's Collectibles, 5388 Sextro Road, Minster, Ohio. 45865 Phone # (419)-628-2345. Nice people to work with, give him a call.
