880 hydraulics
Jim Gutenberger
03-07-2002 11:56:25
I have 880 with two hydraulic outlets. one 2way and one set for oneway and both work accordingly. The problem is that they both tend to raise the trailed implement, mainly a nine ft. haybine. After traveling ashort distance I have manualy to manualy keep lowering the header. Any help guys??? jimg centwis
LynMn
03-09-2002 18:55:33
 Re: 880 hydraulics in reply to Jim Gutenberger, 03-07-2002 11:56:25
Due to the internal plumbing and the use of
check balls in the system, the Oliver hyd. will
do some strange things.A single acting cyl.will
raise a light load with the valve in neutral A double act. cyl. will raise if you have
faulty check ball in hyd.unit.Switch the two
hoses to check this.Single act. don`t work
well on Oliver systems.You always have slight
pressure at the couplers with the valves in neut.
