OC3 Serial Number
Andy Mallory
03-05-2002 17:50:07
I am wondering if anybody can tell me what year and exactly what motor this is. I know it is newer because it has oliver on the exhaust manifold.
The engine serial number is 2447212
Thanks Andy
[polk crawler
03-05-2002 19:57:46
 Re: OC3 Serial Number in reply to Andy Mallory, 03-05-2002 17:50:07
Engine and crawler ser nos are not the same. OC3 ser no is on back side of bell housing, driver side; check that against ser no menu to left of discussion board; engine ser no on an OC3 is below air supply pipe to carb on RH side of block;
I understand Hercules flat six engines were pretty much standard on OC3s.I have no idea how to check date of manu for the engine. Reproduction manuals for an OC3 (operator, service and parts) are available through YT website; click on manuals on menu left side of this disussion board.
Most guys refer to Landis Zimmerman back in Ephrata PA for parts. There is also a source in Lodi, Ca; check with Larry Harsin Oliver link to get the snail mail address; Lodi source has no e-mail; have not seen e-mail for Zimmerman either.
Good luck.PC
Esev
03-07-2002 18:30:32
 Re: Re: OC3 Serial Number in reply to [polk crawler, 03-05-2002 19:57:46
If it is an IXB Hercules flathead four, there is a casting date in the block on right hand side behind the mag.
