88 not equipped with hydraulics
andy
03-04-2002 15:26:11
My tractor has mechanical lift, and i would like some hydraulic power , what is involved with getting rid of old lift and installing a pump and hydraulic unit?
m kuhns
03-04-2002 18:09:47
 Re: 88 not equipped with hydraulics in reply to andy, 03-04-2002 15:26:11
The 77s and 88s use the pto shaft that runs from the engine to the rear to drive the hydraulic pump. All you should need to do is remove the lift unit. Then pull out the pto shaft far enough to drop the hydraulic unit in place. Put the shaft back in and you should have hydraulic power.
Gary
03-04-2002 18:05:38
You have to remove the gear that runs the lift,then cut the back of the shaft off and install the hyd unit. It is driven by the PTO shaft. You do have to pull the long PTO shaft then reinstall after you put the hyd unit on as the shaft runs through the pump.
David
03-05-2002 16:18:02
 Re: Re: 88 not equipped with hydraulics in reply to Gary, 03-04-2002 18:05:38
I have a factory hydraulic unit for sale. Contact me if you are interested. 204-378-2108.
Jeffrey Pokorny
03-05-2002 11:04:48
Is this tractor for sale? Where do live, which state. Send me a picture or something at this address.
Jeffrey Pokorny
03-05-2002 11:04:47
oliver farmer
03-04-2002 17:14:02
not sure but i think that the mechanical lift is driven by a different size gear than the hydrolic unit drive. i believe you would have to change the gear n the trans.
