1952 HG60 Oliver
Dan H
03-03-2002 14:25:59
My HG 60 oliver crawler seems to stuck in a couple of gears . Is there any way to free them up without splitting the tractor? My brother and I have taken the back off the rearend and have taken the driveshaft off, but it looks like we may have to split the tractor to get at the shiftting forks.... Seems like a lot of work. Anyone out there ever have this problem? Dan
Albert Duroe
03-05-2002 21:10:59
 Re: 1952 HG60 Oliver in reply to Dan H, 03-03-2002 14:25:59
Unhook the engine driveshaft, take out the frame side bolts and rotate the rear end up, then you can get at the side of the transmission and fix your problem. Good Luck Spark
kevin
03-08-2002 20:09:34
 Re: Re: 1952 HG60 Oliver in reply to Albert Duroe, 03-05-2002 21:10:59
i pulled the shifter out and used a long handled screwdriver to realign the forks
