Won't Start
Richard Turner
03-02-2002 05:14:56
At Christmas I pullied the head off my 66RC. I had it redone. I put it back on and now the tractor won't start. Plugs are wet so I know its getting gas. I have hooked up to 12 volt so it turns over like a top.
Delbert
03-03-2002 08:50:34
 Re: Won't Start in reply to Richard Turner, 03-02-2002 05:14:56
If the plugs are excessively wet you may be getting too much fuel or a flooding condition. If you connected to a 12v barrery is the polairity correct? Olivers are origionaly Pos ground. Hope this helps Delbert
Tony
03-02-2002 18:26:26
When setting valves make sure #1 intake and #1 exhaust are closed, when top dead center pointer aligns. Also roter in disrubtor should be pointing at #1 distrubtor proceed with firing order of rest. Good luck!!
ken
03-02-2002 07:59:03
Richard, I believe you need to check your valve clearence settings at your rocker arm. on gas these should (adjusted cold) be intake .010 exhaust .016 on diesel intake .010 exhaust .020 if these aren't set reasonably close then it won't start. hope this helps Ken
Allan
03-02-2002 18:07:12
 Re: Re: Won't Start in reply to ken, 03-02-2002 07:59:03
Ken is probably right. Remember the rule. You need compression, gas, and spark. You seem to have gas. You should check the spark, but you weren't doing anything there. So... it's likely compression.
