Perkins 6 -354 in 1950 t
gaetan
03-01-2002 05:43:29
will the 354 perkins fit in the narrow frame
of the 1950 t if yes what do i need will it bolt to my torque.my waskasha crank gone again
thank you. gaetan
Shep
03-01-2002 08:31:00
 Re: perkins 6 -354 in 1950 t in reply to gaetan, 03-01-2002 05:43:29
Yes you can put the Perkins in the 1950-T. The easiest way to do it would be to get an 1850 front frame and switch front frames with the 1950-T. I think Ollie Shafer has a few frames for sale if you talk to him. That way you would have all the mounts you need and everything will line up nice. Be careful taking those 8 frame bolts out to split the tractor, you will bust several 11/16 sockets trying to get them out(my snap on man loves me) Then the only other thing you will need is an 1850 or white/perkins bell housing for your three speed. You can get them at bone yards most anywhere, or Ollie might have a few too. Thats the easiest and best looking way to make it work. You could cut the bottom out of your frame and beat out the Waukesha mounts out, but that is a pain and usuasally looks like you "chewed" the bottom of the frame off.
gaetan
03-02-2002 06:18:45
 Re: Re: perkins 6 -354 in 1950 t in reply to Shep, 03-01-2002 08:31:00
shep 1950 t is fwdrive with 2 speed not 3 speed
will i need the same bell housing thanks gaetan
Jake
03-01-2002 07:30:47
I am glad that you are considering the Perkins over the Cummins diesel. I have owned many White's with this motor in them. They perform very well. Are you planning on putting a turbo back on the tractor? That will make a mean little tractor if everything works out good for it.
